Auto-Negotiation enabled by default for fiber ports 25G and above. Check the peer port auto-negotiation setting as it should be the same.
No action required - Notification message only.
Notice
Auto-Negotiation enabled by default for the transceiver module in port %slotPort%. Please verify that the peer has the same setting.
| Name | Type |
| slotPort | SlotPort |
